Originally Posted by BMWTurboDzl
I recommend against dash cams because they can always be used as evidence against you and if you, in a panic, decide to taper with the camera because of an accident where you're at fault you can also be charged.
That's ridiculous. I worked as an auto claims adjuster and I can 100% verify that dash cams help more than hurt. The only ones who should be afraid are those who cause accidents to begin with.
You can also turn off the "show speed" option. Neither of mine show the speed on the camera while recording.
You don't know that, because you don't know the number of times a dash cam wasn't disclosed. Take a "holier than thou" driver who "brake checks" another driver causing a rear end collision. Point being is that I can see situations where the camera "disappears" when the accident doesn't look favorably on the driver.
Isn't it the decision of the camera owner wether or not they choose to use the footage as evidence?
