Dave1251: How can I be misinformed about conventional oil quality when I experienced the conventional oil failure firsthand in my 4.6L (among other engines)? Also, 90K miles is low mileage for the Modular Motor. Expect the rings to oil-coke and the hydraulic lash adjusters to varnish-stick with oils that can't take care of themselves in this engine.
SmrtJustin: The only conventional oil I would consider running in my '96 4.6L is Castrol GTX 5W-20 because it is a thick 20 weight that is apparently proving itself in used oil analysis. My engine runs super-good on very thick 20weights or very thin 30weights with some stickiness to the oil, thus my Syntec 5W-20 choice.
I highly recommend the 5W-20 in the winter since your engine is rated for it. You will be very impressed by the cold start performance with the 5W-20 in the dead of winter (when all the wear occurs). The Syntec 5w30 is a thin 30weight that might be a good combination oil for both of your engines. You won't have to worry about wear or cleanliness with this oil with 5-7.5K mile OCI's.
