Hello All! I've been reading this forum for months now and it is great!
I have a 1997 F-150 with the 4.6L with about 81,000 miles. Since it was new I've always ran Valvoline 5w-30 dino in it with no problems, then a few years ago I switched to Durablend with no problems, then after reading so much here I decided to try Maxlife in it. I've used Maxlife now for three 3k mile OCIs. I've noticed now using Maxlife that it has started using oil. I can't give you an exact amount because I don't have any spare Maxlife sitting around to pour into it, but I can tell you it has about 1500 miles on this oil change (the third one using maxlife) and the oil is sitting about 1/2 to 3/4 in the "OK" range on the dipstick.
So naturally I'm thinking about trying something else. The two oils I've narrowed it down to are my head is Motorcraft 5w-30 (I know it can now use 5w-20, but I'm not sure with it now using a little bit of oil if thats a great idea) and Havoline dino 5w-30. I always try to do 3k mile OCI, even though most of you will say thats overkill. I also have a 2002 Tahoe with the 5.3L and about 32,000 miles, so it would be nice to use the same oil both.
Both trucks see mostly city driving here in Toledo, OH.
I would really like to hear what your opinions are on what oil to use, and if either of them will cure the oil consumption problem. Its not crisis if it won't, but I just figured since it seemed to develop after switching to Maxlife, that the oil might have something to do with it.
Thanks in advance.
Thanks in advance.
