Tricky flight ticket change fees
Reunion Island
Hi,
we're planning a family trip. When booking tickets, my wife omitted that on her daughter's passport, there's TWO family names. She mentionned only the first one. This is likely to fail at customs or boarding, and the company wants to charge € 150 to modify issue a corrected ticket.
As an example, the ticket is now printed with "DOE John" name instead of what's on the passport "DOE SMITH John"
Discussing of the matter, do you think that :
1- how great this would fail at customs/boarding (I think it would)
2- I can't find the rule for modification charges. I understand when reading that when changing for another flight (time, date, route, whatever) it's billable but...
3- just tell anything you might want to
Quote
CHANGES
ANY TIME
PER COUPON CHARGE EUR 150.00.
NOTE -
A CHANGE IS A ROUTING / DATE /
FLIGHT MODIFICATION. NEW RESERVATION
REISSUANCE AND PAYMENT OF THE PENALITY MUST BE
MADE AT THE SAME
TIME
I. IF SAME BOOKING CLASS IS USED NEW
FARE MAY BE EQUAL OR HIGHER OF PREVIOUS FARE AND
MUST COMPLY WITH
1. THE PROVISION OF THE ORIGINAL
TICKETED FARE
2. OR THE PROVISION OF THE NEW FARE
II. IF A DIFFERENT BOOKING CLASS IS
USED NEW CLASS MUST COMPLY WITH ALL PROVISIONS OF
THE NEW FARE
III. CHANGES NOT PERMITTED ON FIRST NOSHOW
COUPON. BUY ANOTHER ONE WAY TICKET.
IV.INBOUND COUPON IS STILL VALID EVEN IN CASE OF
NOSHOW ON OUTBOUND FLIGHT.
Included the full text below :
Quote
3 - PSGR P2-3 CH RULES DISPLAY
FARE COMPONENT 1 CNN RUNPAR BF NLXNCRTB PU 1 N
FCL: NLXNCRTB TRF: 950 RULE: 0260 BK: N
PTC: CNN-CHILD FTC: ER -ECONOMY RESTRICTED
FARE FAMILY : SMART
FARE FAMILY DESCRIPTION: SMART
RU.RULE APPLICATION
BETWEEN AREA 2 AND RUN FOR NLXNCRTB TYPE FARES
FRENCH BEE -SMART- FARES
APPLICATION
AREA
THESE FARES APPLY
BETWEEN AREA 2 AND RUN.
CLASS OF SERVICE
THESE FARES APPLY FOR ECONOMY CLASS SERVICE.
TYPES OF TRANSPORTATION
THIS RULE GOVERNS ROUND-TRIP FARES.
FARES GOVERNED BY THIS RULE CAN BE USED TO CREATE
ONE-WAY/ROUND-TRIP/CIRCLE-TRIP/OPEN-JAW JOURNEYS.
CAPACITY LIMITATIONS
THE CARRIER SHALL LIMIT THE NUMBER OF PASSENGERS CARRIED
ON ANY ONE FLIGHT AT FARES GOVERNED BY THIS RULE AND SUCH
FARES WILL NOT NECESSARILY BE AVAILABLE ON ALL FLIGHTS.
THE NUMBER OF SEATS WHICH THE CARRIER SHALL MAKE
AVAILABLE ON A GIVEN FLIGHT WILL BE DETERMINED BY THE
CARRIERS BEST JUDGMENT
MN.MIN STAY
FOR ROUND TRIP NLXNCRTB TYPE FARES
TRAVEL FROM LAST INTERNATIONAL STOPOVER MUST COMMENCE NO
EARLIER THAN THE FIRST SUN AFTER DEPARTURE OF THE FIRST
INTERNATIONAL SECTOR.
MX.MAX STAY
TRAVEL FROM LAST STOPOVER MUST COMMENCE NO LATER THAN 12
MONTHS AFTER DEPARTURE FROM FARE ORIGIN.
SE.SEASONS
BETWEEN EUROPE AND RUN FOR BASIC SEASON FARES
FROM EUROPE -
PERMITTED 29OCT 17 THROUGH 21DEC 17 OR 27DEC 17 THROUGH
28JUN 18 OR 17AUG 18 THROUGH 17OCT 18 OR 22OCT 18
THROUGH 18DEC 18 OR 24DEC 18 THROUGH 28JUN 19 OR
16AUG 19 THROUGH 16OCT 19 OR 22OCT 19 THROUGH 18DEC 19
OR 23DEC 19 THROUGH 31MAR 20 OR 01APR 20 THROUGH
27JUN 20 OR 14AUG 20 THROUGH 14OCT 20 OR 20OCT 20
THROUGH 16DEC 20 OR 21DEC 20 THROUGH 31DEC 20 FOR EACH
ON THE FIRST INTERNATIONAL SECTOR.
TO EUROPE -
PERMITTED 04SEP 17 THROUGH 19DEC 17 OR 28DEC 17 THROUGH
03JAN 18 OR 10JAN 18 THROUGH 27JUN 18 OR 03SEP 18
THROUGH 13DEC 18 OR 24DEC 18 THROUGH 29DEC 18 OR
14JAN 19 THROUGH 27JUN 19 OR 03SEP 19 THROUGH 30OCT 19
OR 04NOV 19 THROUGH 17DEC 19 OR 23DEC 19 THROUGH
31DEC 19 OR 11JAN 20 THROUGH 31MAR 20 OR 01APR 20
THROUGH 28JUN 20 OR 01SEP 20 THROUGH 28OCT 20 OR
02NOV 20 THROUGH 16DEC 20 OR 21DEC 20 THROUGH 30DEC 20
FOR EACH ON THE FIRST INTERNATIONAL SECTOR.
DA.DAY/TIME
FOR MIDWEEK FARES
PERMITTED MON/TUE/WED/THU.
AP.ADVANCE RES/TKT
RESERVATIONS ARE REQUIRED FOR ALL SECTORS.
WHEN RESERVATIONS ARE MADE AT LEAST 7 DAYS BEFORE
DEPARTURE TICKETING MUST BE COMPLETED WITHIN 7 DAYS AFTER
RESERVATIONS ARE MADE.
OR - RESERVATIONS FOR ALL SECTORS AND TICKETING MUST BE
COMPLETED AT THE SAME TIME.
FL.FLT APPLICATION
THE FARE COMPONENT MUST BE ON
ONE OR MORE OF THE FOLLOWING
ANY BF FLIGHT.
CD.CHILD DISCOUNTS
ACCOMPANIED CHILD 2-11 - CHARGE 67 PERCENT OF THE FARE.
TICKETING CODE - BASE FARE CODE PLUS CH.
MUST BE ACCOMPANIED ON ALL FLIGHTS IN SAME COMPARTMENT
BY ADULT 18 OR OLDER
OR - INFANT UNDER 2 WITH A SEAT - CHARGE 67 PERCENT OF THE
FARE.
COMPARTMENT BY ADULT 18 OR OLDER
OR - 1ST INFANT UNDER 2 WITHOUT A SEAT - CHARGE 10 PERCENT
OF THE FARE.
COMPARTMENT BY ADULT 18 OR OLDER.
NOTE -
UNACCOMPANIED MINORS 4-11 ARE NOT ACCEPTED FOR
CARRIAGE
SO.STOPOVERS
NO STOPOVERS PERMITTED
TF.TRANSFERS/RTGS
IF THE FARE COMPONENT INCLUDES TRAVEL VIA PAR ON
ANY BF FLIGHT
2 TRANSFERS PERMITTED ON THE PRICING UNIT - 1 IN EACH
DIRECTION
FARE BREAK AND EMBEDDED SURFACE SECTORS PERMITTED ON
THE FARE COMPONENT.
EL.ELIGIBILITY
VALID FOR ADULT.
TE.TKT ENDORSEMENT
THE ORIGINAL AND THE REISSUED TICKET MUST BE ANNOTATED -
NON ENDO/BFONLY/NON REF - IN THE ENDORSEMENT BOX.
NOTE -
TICKET MUST BE ANNOTATED -NON ENDO/TX ONLY/NON
REF CHANGES SUBJECT TO SPECIAL CONDITIONS
PE.PENALTIES
CHANGES
ANY TIME
NOTE -
MADE AT THE SAME
TIME
MUST COMPLY WITH
TICKETED FARE
THE NEW FARE
CANCELLATIONS
ANY TIME
TICKET IS NON-REFUNDABLE.
NOTE -
/FOR NON-REFUNDABLE TICKETS THE YQ/YR CARRIER
IMPOSED SURCHARGE WILL NOT BE REFUNDED/
CO.COMBINABILITY
APPLICABLE ADD-ON CONSTRUCTION IS ADDRESSED IN
MISCELLANEOUS PROVISIONS - CATEGORY 23.
END-ON-END
END-ON-END COMBINATIONS PERMITTED WITH BF DOMESTIC/
INTERNATIONAL FARES. VALIDATE ALL FARE COMPONENTS. FARES
MUST BE SHOWN SEPARATELY ON THE TICKET. TRAVEL MUST BE
VIA THE POINT OF COMBINATION. SIDE TRIPS PERMITTED.
OPEN JAWS/ROUND TRIPS/CIRCLE TRIPS
FARES MAY BE COMBINED ON A HALF ROUND TRIP BASIS
-TO FORM SINGLE OR DOUBLE OPEN JAWS.
A MAXIMUM OF TWO INTERNATIONAL FARE COMPONENTS
PERMITTED.
MILEAGE OF THE OPEN SEGMENT MUST BE EQUAL/LESS THAN
MILEAGE OF THE LONGEST FLOWN FARE COMPONENT.
-TO FORM ROUND TRIPS
-TO FORM CIRCLE TRIPS
PERMITTED.
PROVIDED -
COMBINATIONS ARE WITH ANY FARE FOR CARRIER BF/TX
BETWEEN AREA 2/RUN IN ANY RULE AND TARIFF.
VC.VOLUNTARY CHANGES
IN THE EVENT OF CHANGES TO TICKETED FLIGHTS
ANYTIME WITHIN TKT VALIDITY
CERTAIN DOMESTIC REISSUE PROVISIONS MAY BE OVERRIDDEN BY
THOSE OF BF INTERNATIONAL FARES
CHARGE EUR 150.00 OR HIGHEST FEE OF ALL CHANGED FARE
COMPONENTS - INFANT DISCOUNTS APPLY AND
REPRICE USING FARES IN EFFECT TODAY
PROVIDED ALL OF THE FOLLOWING CONDITIONS ARE MET-
1. FULLY FLOWN FARE NOT REPRICED TO FURTHER POINT
2. CHANGE IS BEFORE ORIGINAL SCHEDULED FLIGHT
3. BF -NCRT FARE FAMILY IS USED
4. NEW TKT HAS EQUAL OR HIGHER VALUE THAN PREVIOUS
TKT
5. ADV RES IS MEASURED FROM ORIGINAL TKT DATE TO
DEPARTURE OF PRICING UNIT
OR -
3. BF -RFRT FARE FAMILY IS USED
TKT
REFUND VIA ORIGINAL FORM OF PAYMENT
ENDORSEMENT BOX- HIGHER NON-REF AMT AND NEW ENDORSEMENTS.
VR.VOLUNTARY REFUNDS
REFER TO PENALTIES CATEGORY 16
If the Air Port is close enough, Id go there and talk with Customs/Screening. I would not pay 150e for a name error.
But I'm a home -body; I don't go out of the Country.
It's funny that I traveled West of the Mississippi for the first time last month.
Talk to a person. This isn't a change, it's correcting an error.
The website will charge you.
Customer service agents have discretion.
Be nice.
Be nice.
I've been to the sales counter at the airport, like, 3 months ago when I saw the mistake. I've been nice as usual on a first encounter, and they told be "sorry, any modification will be charged $ 150. If it would be like less than 24hr after buying, we could have done it for free." It's a low-cost company, I understand that they have directives to earn any bonus money from needy customers.
Seems like I'll try on phone and pay if nothing else is doable from my perspective.
It will give you some hassle but you'll make it through.
My poor wife passport has two names that US passport agency did not put a space between her old last name and our family last name. It pukes issues everytime they force us to use kiosk's and have to head to counter.
At least, we learn that we should be VERY precise when putting the name of an airplane ticket and anything you need to use ID.
