Upcoming auto transmission failure at 207,000 miles
Looks like it has finally happened to me even after fluid and filter changes every 35,000 miles and driving like an adult.
Really starting to slip when shifting gears in Economy mode. Less so in sport mode. Was only slippling when shifting to 3rd. Now most every gear. Also I often get a slip then fairly hard shift. No trans code error. fair amount of slipping for shifts when under moderate acceleration. Less so when under light accelleration. I also experience an ocassional delayed reverse engagement.
Do not see any leaks and fluid level is fine when it was checked a month ago.
None of the transmission shops in my area can seem to do any diagnostics without a teardown. None of the BMW indy shops can do diagnostics or rebuild transmissions. They install used or rebuilt units. I have not checked the dealer yet for diagnostics
My BMW dealer wanted $4,900 for a rebuilt unit not including labor. local transmission shop rebuilts were about 2 grand with a 12 month warrenty Then there is a rebuilt unit with torque convertor and electronics update from a nationally known euro transmission rebuilder for $3,500 with a 30 month warrently to be installed by a local BMW indy shop.
Nope, I do not want to convert to a manual.
Guess I will just have a rebuilt transmission installed after I confirm the problem. Hate this, but car is in excellent shape otherwise and do not want to buy another car at this time.
