Hello,
My car sat without being driven for about a year, but I would start it up once every few weeks to keep the engine seals from drying out. Recently, I got the car on the road, but the transmission seems to be slipping a little in all gears. The fluid was about a litre low due to some gasket seepage. I noticed the ATF had also turned slightly brown, but does not smell burnt. The colour wasn't noticeable by looking at the dipstick, and I only discovered it when I put a few drops on a white rag. I plan on doing a full fluid change soon, but is it possible that my transmission is damaged? Can ATF start turning brown from sitting? Is ATF less effective after sitting?
TIA,
Alex
TIA,
Alex
