Transmission out at 78k miles
Originally Posted by nascarnation
These failures are due to a quality issue with the steel clutch wave plates which fatigue crack and cause the plate to separate into two halves and become dislodged and unable to work properly. To the best of my knowledge, this failure is only dependent on number of times the pack has been activated. No relation to amount of torque applied or lubricant. When the parts are mfg correctly, no issue exists, so your re-man should be fine.
Just as an fyi, my daughter worked for a transmission shop and she said those specific stock transmissions in this specific vehicle seem to automatically drop dead between 75k and 100k miles.
Originally Posted by oilpsi2high
Did you start with the basics and check the fluid level? Is the filter clogged?
Did you scan the computer for codes?
Lifetime fluid is a bunch of nonsense IMO and is one of the few things I agree with Scotty Kilmer on.
Athough I would have serviced the tranny sooner, if you clog the filter in 78k miles, you already have some issues brewing. GM transmissions generally have been weak and nobody but only the original owner knows how the vehicle was driven in its first 70k miles.
