Vehicle Acura SLX 99 3.5L V6 with 4L30E Strasbourg GM Transmission.
History:
Bought truck with 4118 mi on ODO had tranny drained and flushed by Acura dealer at 30K.
Had tranny drained and flushed at 56K by local lube shop. it was refilled with M1 Synthetic ATF.
Had ATF tested by Herguth Labs/ sample taken by AAA Diagnostic under the oil scan program.
Oil Scan only gives limited results no TBN etc.
Truck had 73K+ miles on ODO.
Iron - 78 ppm
AL - 7 ppm
Chromium - Copper - **222 ppm
Lead - **41 ppm
Tin - **9 ppm
Nickel - Silver - Silicon - 9 ppm
Sodium - 11 ppm
Boron - 80 ppm
Zinc - 55 ppm
Phosphorous - 282 ppm
Calcium - 263 ppm
Magnesium - 2 ppm
Barium - 69 ppm
Moly - 1 ppm
Potassium -
Oxidation Abs/cm - **48
Water FTIR % Vol - Nitration Abs/cm - Anti-Wear Abs/cm -
note:
1)all double asterisk are abnormal range
2)Oxidation results are skewed by the synthetic makeup of the AFT
3)Cu, Pb, etc indicate bronze component wear.
4)The lab notes that there is little or no database for AFT UOAs in general or for 4l30E tranny.
5)My tranny specialist said that the wear was not unusual or significant. You cannot compare this with Engine UOAs.
Vehicle use included off roadingin UT, AZ, CA, and High speed runs through the desert in high temps. This was my first UOA.
History:
Iron - 78 ppm
AL - 7 ppm
Lead - **41 ppm
Tin - **9 ppm
Sodium - 11 ppm
Boron - 80 ppm
Zinc - 55 ppm
Calcium - 263 ppm
Magnesium - 2 ppm
Barium - 69 ppm
Moly - 1 ppm
Potassium -
note:
