Originally Posted By: CourierDriver
At the shop I go to for transmission problems the shop owner will not change transmission oil on an automatic over 100k miles period or if the car is over 8 years old. He says and this is view point, if you change out old transmission oil on aged cars or high mileage cars that never had a service, you are asking for trouble and he has been doing this for over 30 years now. But to each his own...................its your transmission, some shops will change it, and some will not. If the filter clogs up , he will save the old and pour back in and this seems to work for them. I know it does not sound correct, but hey, Im not a transmission expert.
Sounds about right.. I come from a similar school, of how "you don't want ot go putting ALL in at one time on a never touched trans, could have something happen you didn't expect." 50% the first time and a short time afterwards seems to alleviate anxiety.. again, not found in owner's manuals advice, but when delaing with unknowns, hey, its never killed one on me yet. Maybe unnecessary? sure.
But dirty/working vs clean/dead.
Originally Posted By: Jaxon
Both need doing, Malibu, look color arn,t toooo bad but not great
Rendezvouis not good color or smell
Jaxon, can you do a normal drain/fill on each, and then do a pan drop about 1000 miles later? ? Maybe that will alleviate fears.
Is the fluid BLACK? You are amongst friends here, you can tell us....
I have seen two GM cars with BLACK fluid, but both older, and neither even remotely comparable to your Malibu or Rendezvous.
Both worked fine with a drain and fill, that fluid was nasty...
