A friend of mine over on ToyotaNation has a 7th Gen Camry ('12-'14) with the U760E transmission 6 speed auto. We Camry guys recognize some of the delicate nature of a very busy 6 speed transmission as well as the rapidly firing selenoids in and out of torque converter lockup. Thus many are doing drain and fills.
The drain and fill have to be done very accurately to maintain a correct fluid level. The actual Toyota fill level procedure is complex. Here's the issue... despite painstaking measuring, accounting for cling on funnels etc.....The first time he drained (factory fill) 2190 ml @ 68F, the second- less than 2080 ml @ 65F and the time 1925 ml @ 60F. He's getting less each time. ALL parameters such as garage floor tire inflation are all kept constant. some are saying the new fluid is clinging more internally... not sure if I believe that. Others say that despite his accounting for funnel and container cling... that he is under filling slightly each successive time.
Your thoughts?
Your thoughts?
