Not using trailer tires?What are they doing wrong ?
Trailer tires and truck tires aren't constructed the same.
My trailer tires age out, i've never worn a set out.My brother and law tells me I need to take the weight off my travel trailer tires (lift the rig) and the life of the tires will be extended. How much he did not say. Any opinions on that?
I personally don't like LT tires on a dual axle trailer. Mostly because of the way they scrub it tight maneuvers. I guess on a fiver in the dirt it would not be to much of an issue, but there are plenty of good trailer tires available once you get 15" and bigger.Not using trailer tires?
Over at TireRack it looks like many of the Goodyear Endurance are up to six months our for delivery. But they do have a TT tire Hankook Vantra. Hankook is a well know brand. If I was in need I'd probably go with these as the Goodyear's are backlogged.
These appear to be a a new offering.
VANTRA TRAILER
The load range in 215/75/14 matches the goodyears i just bought, higher speed rating, not that i go over 70. But may be a good tire!Over at TireRack it looks like many of the Goodyear Endurance are up to six months our for delivery. But they do have a TT tire Hankook Vantra. Hankook is a well know brand. If I was in need I'd probably go with these as the Goodyear's are backlogged.
VANTRA TRAILER
I just attended a seminar put on by Dexters lead trainer for dealers and consumers. He commented that the EZ lube system was developed for boat trailer consumers who needed an easy way to keep the hubs full and keep water out.Right I'm saying that all 4 utility trailers I owned spec'ed 50psi which was the max on the sidewall as well.
The tow dolly I had also spec'ed 50psi which was the sidewall max.
I'm not saying to inflate them to 50psi based off the tire sidewall.
I was saying in many cases the number is the same.
Although I've run lower if the load is light or fragile. Dont need 50psi for 400lb of furniture
While we are talking about best practices.. its also good to get some fresh grease in the wheel bearings if equipped with grease zerk.. I try to at least yearly.
my current trailer is super easy. It has the EZ lube feature
I usually do it after returning from a trip.With the EZ Lube axle Ive also read that if you pump in the grease cold it can blow out the back spindle seal and contaminate the brakes. Its best to slowly pump grease in while still hot from travel.
I just picked up 2 Carlisle Reliance Radial ST 205/75R15 LRD load range D from Walmart. Max pressure says 65psi. Walmart inflated to 50psi. I didn't put them on trailer yet since it's raining and I need to clean up studs. Impact gun was working hard to get the lugs off.Couple of thoughts:
First, EVERY TIME!! before towing, check the inflation pressures, torque the lugnuts, and rub a GLOVED hand over the tread surface of each tire of your trailer. You're looking for a bulge. Find a bulge: Replace tire NOW!!
I recommend a pressure build up test: Check the inflation pressure immediately before starting out on an extended freeway speed run (for an hour). The pressure shouldn't build up more than 10% - excluding ambient temperature affects (2% for every 10°F change in ambient temperature).
