I bought an old car, late this summer. After getting new tires, the tire shop (Discount Tire) said 3 of the 4 wheels were bent. They wanted a fortune just for steel wheels, and since I didn’t want to mess with hub centric rings with aftermarket wheels, I bought some OE alloy wheels from the junkyard and painstakingly refinished them.
I specifically requested when they remount the tires to the new wheels to keep the front and rear tires paired together. They said of course they would – that’s “normal and expected".
Well, they put the front tires on the left side of the car and the rear tires on the right side of the car.
I realized this after I got home and started moving the tires around since I still had a vibration in the front (wanted to determine if it was the left or right front tire that was causing the vibration). Ultimately, I rotated both sides of the car and that’s when I discovered the problem.
Not only did they put both front tires on the left side of the car but they mounted one of them backwards – meaning what was formerly the outside of the tire was now the inside of the tire. They may have done this to the rear tires too but I can’t tell due to there being a lack of a wear pattern.
Anyway – I was able to eliminate the vibrations BUT now the car pulls pretty hard to the right, on the freeway.
I really don’t know if I want these idiots touching my car again. They screw something up EVERY SINGLE TIME – I’m not exaggerating. It’s a 30 mile drive in, each way, and usually a good 1 to 2 hours of wait time every time I go in there – it’s extremely frustrating.
QUESTION: If I leave everything as is, will the pulling on the freeway hurt anything and will it resolve itself? I know the alignment is good – just had it done after I got the tires, and the pulling wasn’t there before the “wheel / tire swap”.
The tires only have 3000 miles on them and the depth is the same, or virtually the same, on all tires. But of course, the wear pattern is different.
Thanks,
Thanks,
