I just noticed rear tire wear on my 2004 Dodge 2500 4x4 5.9 cummins. Tires are expensive, so I try to keep an eye out for feathering and cupping on the front tires especially. I noticed this on the REAR tires the other day. You can see the feathering on the driver side mostly, but they are both feathered on both edges.
I sent the same pictures to a guy I know who owns his own shop. He sent the pics to his alignment guy who said it could only be a bent axle or recently rotated tires that the front chewed up. I had the tires rotated and rebalanced in California before I headed back to the east coast.
At that time, the front and rear tires were smooth as glass and the front end didn't need an alignment. I drove back with a uhaul cargo trailer in tow. Forward about 8000 miles since leaving California, this is the wear pattern. I took the truck to a tire shop. They put it on the rack but said everything checks out. But they said an alignment would be a good idea. I told them the shocks all the way around are over ten years old and tired. I have them on order and once replaced, I'll bring it back for an alignment.
So what could cause this wear? It's a solid rear axle with leaf springs, so there isn't an adjustment that I'm aware of. I'm thinking bad shocks or weak rear leaf springs? Any advice appreciated.
Thanks
Thanks
