In my two late model V8 Tundra and Sequoia, I use synthetic 10W30 in the winter and 10W40 in the summer. No change in gas mileage or oil pressure. The engines are quieter and smoother. The cold "piston slap" in the Tundra is almost gone.
Some engines see far more cold starts per 1000 miles than others. Some engines see far higher ambient temps and loads than others. The one size fits all oil spec is a fallacy IMHO.quote:
Originally posted by Pitbull:
Isn't 90% of the wear on your engine at start-up when there is no load on the engine? I would agree that a heavy 15w40 oil would be good for a Cummins Turbo Diesel engine that is worked hard with heavy towing but most passenger vehicles get most of their wear at start up when they are cold. That is why a Mobil 1 5w30 is better for the durablity of the engine.
Yes, thank you. That's the whole point: you should use common sense and pick a viscosity grade based on use and ambient temperature.quote:
Remember Toyota recommends heavier oils in other markets in the same engines for high temp conditions. Drivers like myself who have relatively few cold starts per thousand miles and live in hot areas may compromise towards a higher viscosity.
Makes sense for you. I think I will stick with the Mobil 1 5w30 since I only drive unloaded and in a mild climate. I usually drive my LC somewhere everyday around 20 miles round trip. But not stop and go traffic, I live in the country and drive into a small town (100,000 people) during none rush hour conditions. I think the oil should be some what based on the use of the vehicle and climate along with the manufactures recommendations. JMHOquote:
Originally posted by Grossomotto:
I have the absolute worst driving conditions ever! 100+F, stop and go ALL DAY long around town. Never getting over 40MPH and I make 20+ stops, turning the engine off-on. The Mobil 1 5W30 gets pureley punished, to say the least. That's why I'm going to Delvac 1 5W40.
much as it embarrasses me to say it, I used to think EXACTLY that way.quote:
Originally posted by heyjay:
Exactly Dr T.
Most For example, they wander into Canadian Tire and see two bottles of oil side by side.
One bottle is the absolute cheapest oil ever made, maybe $0.65 a litre. The other is a "medium priced" synthetic like Mobil 1 10W-30, maybe $8 a litre at Canadian Tire.
Now since both have the API "Starburst" both have to be "equally" good so why on earth pay for the more expensive synthetic? After all, they're both "good!" See where the confusion comes in?
