- Joined
- Nov 16, 2022
- Messages
- 29
I would like to flush a 1GR-FE Toyota with distilled water, drain 50% and refill with a concentrate.
Engine has had an 8 qt dealer flush prior (capacity is 10.4 qts) with Toyota SLLC.
I have used PEAK OET Extended Life Red/Pink Concentrate Antifreeze/Coolant for Asian in another later model Toyota recently.
Also available easily via Amazon is:
Recochem OEM 86-174POEM Pink Premium Antifreeze Concentrate
amazon.com/gp/product/B00U1OOOE8
@Sayjac et al
Any reason to select one product over the other, chemistry wise?
Or choose the dealer method and drop and replace 8 qts with Toyota Super Long Life Coolant?
Thank you
@Sayjac et al
Thank you
