Toyota oil
Virginia
Is the bottled Toyota oil made by mobil? If so is it the same as mobil or diff. for toyota specs? Does anyone use it? I use only OEM parts and would like to run toyota oil in my 04 3.4 tacoma but for $2 a qt. im wondering why?
And this is from the same Toyota dealer that wanted $32 for a cabin air filter on my '03 4Runner and an hour labor to replace it. The same filter is available from parts stores for from $18 to $22 and takes five minutes and the removal and replacement of one screw, oh, and you have to open the glove box, too. You're smart to look around....
What a bargain, mine (had i bought the replacement) was $54 USD for the !Echo! I ended up using a hose, simple green and 5 minutes of time.
