TOYOTA OIL DRAIN PLUG GASKET
out of all brands i have owned, my favorite is still Nissan's copper drain plug gasket.
Yep, looks like the same 10mm aluminum crush washer I got from Scamazon. Works great. The OE Toyota one I took off, ( which I had just installed 1k prior), was already " loose", and I had the rubber/felt part facing the pan. Yes, the pan is wavy. The OE washer had a wave in it. You'd think something as simple as an oil pan, Toyota would get it right. The consequences of that plug coming out while driving would be quite costly, to say the least...But it seems not everybody is having this problem. Hit and miss type thing. I have 2 Toyota's, with the 2AZ-FE engine, with this problem.
Approx what torque are you using? I stop at about 25 lb ft and all's good.
I don't torque, go by feel. After almost 50 years, you get a feeling when to stop. Those Nissan washers are the BOMB ! There a PITA to get back off though, sometimes, especially if you have a customer who has been using the same washer over and over.
My question was approx how much torque are you using, by feel or whatever. Toyota washers are fine; there must be some other factor. Hundreds of millions have to have been successfully used over the years.
Regardless, good luck.
I have two (2) Camry's...both with the 4-cylinder engine. I change oil in both of them ~ 2x per year. I use the Toyota oil drain plug gasket pictured below and torque both drain plugs to 18 ft-lbs per Toyota spec. Over the past 2 years, I've noticed that both drain plugs are finger tight at best when I change the oil. I've noticed that the coating or whatever is on both sides of these aluminum washers disintegrates...mostly on the side of the gasket that is in touch with the oil pan. FWIW both oil pans are metal. The drain plugs are both the original and are perfect. You can hand tighten both bolts snug and then tighten with the torque wrench. FWIW I have two different torque wrenches I've used to make sure there is not a problem with the amount of torque applied. I have in the past bought packets of washers from a Toyota online parts dealer and really haven't had an issue. I went to my local dealer and bought a few washers for the most recent change to see if I would get a different result....same problem. Within a week both drain plugs have loosened to where you need to tighten the bolts another 1/4 turn or more. Thankfully neither drain plug has completely come out. Generally they seem to about one to two turns to being hand tight.
Question...has any one experienced this problem using TOYOTA drain plug gaskets? For reference here is a picture of the gasket and the Toyota p/n.
P/N 90430-12031
I own a new Toyota and love it. It is ashamed they can engineer and build engines capable of running over 300,000 miles with proper maintenance but are having problems with engine oil drain plugs and gaskets! LOL!
I haven't used or ordered these for my new Toyota yet, so I don't know if they are junk or not, but the plug is magnetic. I will post an Amazon link to both the plug and gaskets here, if you are interested. There is also this thing out there called a "Fumoto Valve" drain plug you can look up if you are interested.
https://www.amazon.com/dp/B07YVKL6D...Z867P9ED7&ref_=list_c_wl_lv_ov_lig_dp_it&th=1
https://www.amazon.com/dp/B09NF4Y9C...867P9ED7&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
There is no problem to be solved. If the plug loosens up with a properly tightened drain plug and Genuine Toyota drain plug gasket, you need a new oil pan. It is that simple.
I'm not knocking Toyota oil pan washers at all. It's more of a probability that my old oil pans, ( 06' & 03' ), have warped a bit where the bolt seats on the pan. I have steel pans. I don't know what Toyota uses nowadays. Is it still steel, is it aluminum ? I can't answer that. Honda has been using aluminum pans for quite some time, other manufacturer's still use steel. Steel warps, bends over time. I am not the original owner of my 2 Toyota's. I don't know who's been under there. But, on a personal level, I found a solution. Using just plain 10mm aluminum crush washers work for MY particular situation. I put new drain bolts and these plain aluminum 10mm crush washers, and it worked. Just happy the pan threads are not stripped out. They are quite old. Yes Critic, I agree with you 110%. New pans will solve the problem.
I use the first regular copper washer (I don't use crush washers) I installed 7 years ago when I bought the car or the copper washer the last person installed before me. Always hand tighten the drain bolt and never had a problem with it on my 2AR-FE Camry engine.
Info from Toyota nation, I've never read on that site:
https://www.toyotanation.com/threads/oil-change-torque-specs-14-camry-se-2ar-fe-2-5-4cyl.1017378/
The OP probably over tighten the oil drain bolt and then started using a torque wrench. But it was too late because the oil pan thread was already stripped.
Glad to hear the plain copper washer works for you. The 10mm aluminum crush washer works for me. So, there are options out there. I remember as a teenager, I stripped the threads on my 351 Windsor oil pan. Went to the auto parts store, ( there was no internet back then, no you tube videos), and the guy behind the counter pointed me to the " Dorman Spin Rack " That's where I found those one use only rubber oil pan plugs. Bought a bunch of them, and that was that. They never leaked. I was happy. Didn't have the money to buy a replacement V-8 oil pan. Sold the car a year or so later with that rubber oil plug in the pan.
Man, you are probably right, but I bet that job is more than a $10.00 bill. It sucks.
Steel bends and warps over time with regular care? Maybe if it gets hit. My fleet of old Mercedes Diesels that have had high mileage and use steel oil pans might disagree with this. They have zero issues and I’ve had some tight drain plugs in them.
What I have encountered though with Toyota were poorly made oil drain fittings in even the finest Toyota products such as the FJZ80 Land Cruiser AT drain pan. To me it’s as simple as that they allow poorly made drain plug fittings on their products. Not that some warp would deform fittings on their heaviest/thickest part.
Very good observation. I went back with new OE Toyota drain plugs., ( with the 10mm aluminum crush washers). If I encounter this problem again, I'll switch the brand of plug and see what happens.
Wil be interesting to see”read” the washer. If it gets gouged or bent…
No doubt the washer will be wavy/bent when I do the next OCI. It's an aluminum crush washer. Not as strong as the plug. Listen, the Critic nailed it, plain and simple. New pans are needed. But, I'm not buying new pans for an 03' & 06' Toyota. Their not rusted or dented. The aluminum crush washer's work fine. I checked them, they did not loosen up or leak. Some guys may have better luck with a copper washer, or a Nissan type of washer. Trial and error is all I can say. ( The story of my life anyway...self taught...LOL :) ) Here's another story. NEVER did a strut until 2020. They were quik struts. Not a clue where to begin. You tube'd a bunch of videos, and dived in. ( good thing I had an impact gun :) ).....And Viola !!! An aching back later, and they were done. LOVE that sense of accomplishment. Keeps me wrenching :)
changed the corolla oil on June 2nd. On a whim decided to check the plug yesterday evening and lo and behold, it needed a decent amount of tightening.
These are aftermarket washers and it seems that the heat from the oil pan degrades the felt/adhesive possibly leading to the bolt loosening. switching to non-coated crush washers going forward.
Just had this same thing happen on my Camry and remembered this thread late last night. Took of my drain plug and parts of the coating just disintegrated off.
Weird, I've never seen the gasket deteriorate, even after using the same one for many years.
It wasn't deteriorated, but the 20mm, aluminum fill plug washer/gasket on the Legend was re-used so many times (before I took ownership) that it actually "flowed/curled" around the OD of the plug. I had to clamp the washer in a vise to unthread the plug from it. I wish I had an image of it.
