TOYOTA ECHO
quebec....canada
the wife has a 2000 toyota echo with over 100 000 miles and i have never changed the antifreeze ..it is still pink and seems very clean ..i checked the antifreeze and it is still good for -35 f ...don,t know why everybody is so worried about antifreeze ..ps . still running on stock waterpump and still get a lot of heat in the winter ..am i missing something ??????
Canada
It may appear good, but best to test it with an acid strip. Chances are the mixture is now a bit on the acidic side. You can get the strips online (can't remember where, its been awhile since I got mine) or just take it to to a shop for a quick test.
Bill in Utah
Staff member
UT
I've got 135k on my factory fill and waiting for some free time to flush it out and put in the Peak Global I bought for my 05 Corolla. But you can not go by looks here. Test it or change it! Bill
JHZR2
Staff member
New Jersey
Modern antifreezes are all good for 100k I believe. I don't know of any manufacturers that don't have a coolant that is roughly that use interval.
San Antonio, Texas
No, you are not missing anything... but chances are you are headed towards something. Check the maintenance schedule for your vehicle... I think you will find that you are LONG past the antifreeze change date.
browning300wsm
quebec....canada
ok changed the antifreeze this morning ...no big deal ..used GLOBAL ANTIFREEZE [OEM] for all makes good for 5 years or 250 000 kilometers ..bought the antifreeze at CANADIAN TIRE ...
Everett, Washington
Now don't you feel warm and fuzzy knowing you have fresh antifreeze?
browning300wsm
quebec....canada
 Originally Posted By: paul246
Did you use distilled water?.... or is the stuff you used a premix formula?
i used rain water that i collect in a 45 gallon barrel .i filter it through a fine filter mesh and use it to water the garden .i alway's have a gallon on hand for the car. i do not use premix formula ...
