Quote:
Quote:
Brian and Black Bart - you have obviously had not much experience of European cars! The Japanese Toyotas I now run are a revelation.
Supposedly the worst cars on the road today in terms of reliability are still better than the best of 10 years ago.
10 years ago I had a 1995 Ford Contour. CR rated it very low. That car is still on the road approaching 200K miles. It needed a waterpump, some sensors, and some suspension work to go that distance. Everything else was usual maintenance (tires/batteries/brakes/bulbs/etc.)
I drive a 1995 Toyota Avalon and there is no problem it has ever had that has kept it from being driven. I had two relatively minor (according to the figures provided by Geico) repairs this year that are the first non-standard maintaince repairs that the car had in its history and both of them were more preventative repairs than actually necessary. I preferred to eliminate the oil leak that using Mobil 1 started and I also preferred to eliminate the possibility that the power steering would have a failure when I was driving, as certain components of the power steering were starting to fail (e.g. a steering column gear was damaged, the power steering pump was leaking and a power steering fluid hose was leaking).
It did not technically need either of them, but I like to take preventative measures (i.e. fixing power steering components before I get into a collision, eliminating leaks before my engine runs low on oil) rather than corrective measures (i.e. dealing with the insurance company following a collision that was the result of negligence, dealing with the insurance company to replace an engine that was damaged as the result of negligence).
I think that a Mercedes-Benz designed before the 1980s would be just as reliable if not more reliable than my car, with the same going for durability. The same goes for a Chrysler designed before the 1960s. After all, Chrysler and Daimler-Benz's subsidary Mercedes-Benz were the engineering companies of their respective periods. I think that if car manufacturers expect us to believe that their current vehicles are more reliable than what was made in the past, I have a bridge I can sell them. Perhaps their new stuff is more reliable than the garbage they tried to sell us in the past (e.g. my uncle's Chevrolet Blazer), but it is certainly not more reliable than vehicles by the manufacturers in the periods I mentioned.
By the way, regarding Toyota's new stuff, my mother purchased a brand new 2008 Toyota Avalon and the only complaint I can find is the fact that it suffers from obsessive vent opening disorder. Every time the car is turned on, it fails to remember that the vents were closed the last time it was operated. Having allergies, this is not something I like, although the cabin air filter really lowers the level of allergants that enter the cabin as opposed to my Toyota Avalon. Based off my experience so far as a passenger in my mother's Avalon, I really think that the problems are far more limited in scope than Ford, GMC and Chrysler fans would like it to be (i.e. restricted to the Toyota Tundra and Toyota Camry V6).
