Balance shaft assembly on the 1AR-FE 2.7L in the Sienna was getting noisy. Lots of rattling at idle, some googling led me to confirm that was the culprit since I'd already taken care of the cam phasor.
Also read some accounts that the balance shaft assembly can be completely removed, oil galley plugged, and there's only a small increase in engine vibes will freeing up a little power. So I thought I'd try it
Oil pan off, accessories unbolted, assembly removed, taken apart
Rather than drill and tap a hole in the block I opted to plug the entrance hole on the balance shaft housing. The housing can be put back on to retain engine block stiffness but remove the actual shafts and stuff. And then the process is reversible.
Housing all ready to go with hole plugged. I drilled three holes at the bottom too to allow oil to drain.
Bolted back up
Oil pickup thingy gets a new OEM gasket
Oil pan is all ready for some Toyota black FIPG
to be continued...
Bolted back up
to be continued...
