2004 F-150 4.6L w/ 4R70 and 8.8" rear (currently 47,000 miles)
Towing 800lb. trailer + 1000lb. load for about 200 miles round trip on the weekends. I have read that the weak point of this transmission is the OD band and that towing with OD on can cause problems with this. The question is if I am towing at 70 mph should I be in OD or spinning the engine a little faster w/o OD. I am not concerned with the engine as I am positive it will never give me problems. I am debating because I have always thought that towing w/ the OD off would cause higher transmission fluid temperatures (no converter lock up) but also do not want to cause damage to the OD band in this transmission by towing with the OD on...? Is this load light enough that it shouldn't really matter either way?
My thoughts are that if it stays in OD and isn't constantly down shifting to tow that way and take OD off only if it is always shifting to a lower gear.
What would all the BITOGers do?
