Adding tranny fluid temp sensor and towing in OD
Yes my additional cooler is in series with the radiator cooler. I have the additional cooler first in the loop so the radiator can help warm the fluid in the winter. Not that the winter temps in my current location are very significant.
I've really been wanting a transmission temp gauge for a while now, so I will be adding one whether or not I tow a trailer cross country.
How difficult is it to remove the pan with the gauge sender installed in the pan. For inspection and cleaning while not under the Van?
Should I go electric or Mechanical?
I'm against towing in OD. I've always just turned OD off and used 1:1 always seems to work work and never had a problem hauling heavy loads.
