quote:
Originally posted by Matt_S:
The biggest reason you always hear the recommendation to tow with an automatic is that you'll burn through clutches much faster when towing with a stick. That holds true for any "light duty" vehicle, be it a FWD sedan or a RWD pickup.
Semis are a different animal, though. You don't ride the clutch when driving a semi. From a stop, you press the clutch, put it in gear (usually second, first for very heavy loads) then pull your foot completely off the clutch pedal. The gearing is so low and the engine has so much torque that the truck will just start rolling slowly. You then apply gas to accelerate. Obviously you'd stall a normal car or truck trying to do that.
