Torque wrench with angle
Golden Meadow, LA
Im looking for a decent digital torque wrench with angle that wont break the bank for DIY stuff. Has anyone tried the ones from Amazon? The intake on my truck calls for 89 inch lbs plus a 45 degree turn, in the past Ive just torqued it to 89 and then eyeballed a 45 degree turn, spark plugs are due again soon and even though I havent had issues Id like to do the angle right. Passenger side requires intake removal. Id love to get a snap on but its not in the cards right now.
I have the Gearwrench 3/8" drive digital flex head. Used it for the rod bolts on my BMW M5, the head bolts on a Chevy 5.3, and other jobs. It was a good buy. I take the batteries out when im done using it.
https://a.co/d/fHLuLiL
I second @rijndael on the Craftsman. It's a great buy at that price on Amazon. These are identical to the DeWalt digital wrenches, just in a much nicer color 👌
I think Ill have to get a 1/4 drive for the low torque requirement
That small I just use a regular 1/4" in/lb torque wrench and mark the angle with tape or eyeball from a frame or crossmember and a regular wrench for the final turn. That's been working for me for decades and I've never broken aluminum screws or had a leak with Mercedes and BMWs.
When I eyeball the degree rotation, I use the points on the fastener head as a marker, they're 60 degrees apart.
Transfer the internal points in the socket to the outside of the socket, I use a sharpie, so you can watch it while you turn it. Put a reference mark on the engine/intake/whatever you're putting the bolt in. Turn it until you're 3/4ths of the way to the next full index mark.
.75 * 60 = 45 degrees.
