Torque Sticks for Electric Impact Wrench
Ontario Canada
I may get a set of torque sticks. I have 2 electric impact wrenches. One is 7.5 amp, 240 ft. lbs. and 2700 blows per min. the other is 3.5 amp, 220 ft. lbs. and 0 to 4000 blows per min.
I heard that torque sticks are designed for air impact wrenches and will not work properly with electric impacts.
Any advice please.
If it requires precise torque, don't use an impact to tighten anything past nearly snug.
Torque sticks are useless unless you're a tire-shop and can get away with being 20-40ft/lbs too-tight per lug-nut.
My 2c.
I just sold the torque sticks I bought 6 months ago. Yes, they seem to work, but you get no feedback like you do from a torque wrench. It is like, maybe they are right, but maybe not. I could tighten by hand without a torque wrench, and have a better feel than using a stick. Plus being several inches long, they are awkward to use.
I used to use them with my IR electric impact.
The torque sticks will be calibrated for a specific strength impact.. sometimes 350ft/lb
If you use them a few times with your electric impact you should be able to get a feel for how tight it gets... will be a percentage off the number on the torque stick
So in your case with my torque sticks you would use the 80ft/lb to get near 65ft/lb
Since I have pretty much retired my electric impact and use my Porter cable battery impact
They are not used often. Its very easy to get the lugnuts to 65-75 with the PC impact then final torque with torque wrench.
As long as the lugnuts move before the torque wrench clicks.. its fine. If not I back it off slightly and start over.
I have owned them and honestly i wouldn't waste someone elses nickel on them. I use an impact to remove lugs and to run them up but final torque is always with a torque wrench.
Do yourself a favor and buy a split beam instead, you don't need to set it to zero every time and you can leave it set to the most common wheel torque i leave mine at 90.
This is a good one for short $$
http://www.tooltopia.com/precision-instr...CFc2PHwodpssL9g
Originally Posted By: Chris142
I only use the 65ft lb one since 99% of lugnuts are torqued more than that. I run them down to the 65 then finish with my tq wrench
This really is the only smart way to use a torque stick, IMO. This is what I would do when I worked in a tire shop.
