AutoMechanic
Site Donor 2025
Hope you used anti seize. If not good luck getting them out in 100,000 or however many thousand they are good for.
Aftermarket ngk ruthenium......Did you use the OE plugs? Because the OE plugs usually are pre-gapped
(you don't have to buy them from the dealer, as the same OE plugs are available in the parts stores or online)
Much better now.
Thanks everyone.
I just snug them up.Hi car gurus.
I would like to inspect my plugs.
When I put them back in what torque spec should I use?
The same when I installed them?
Thanks everyone.
Hi car gurus.
Thanks everyone.
Ja, Gütentaght! Seriously though, hold yer ⅜" by the head on your ⅝" socket (or whatever fits) and just one good ham fisted uhg! That's all.The German way, gut-en tite.
Carefully. Very carefully. You don't want to buck the rare earth buttons off the tip(s). Just barely touch them with your gage to find where you're at. Use the other side of your gage (if it has the toothy looking bit on it) as a mini wrench to adjust the gap by only twisting the ground electrode above the spark plug threads, not leveraging or wedging anything *between* the electrode tips.I didn't know those could be gapped!![]()
Me neither....I called ngk to make sure.I didn't know those could be gapped!![]()
It took me a while to carefully open the gaps. But I got em. Needle nose pliers.Ja, Gütentaght! Seriously though, hold yer ⅜" by the head on your ⅝" socket (or whatever fits) and just one good ham fisted uhg! That's all.
Or use fine needle nose pliers to apply pressure only to the ground electrode, again, just above the threaded barrel. Check with gentle strokes of the gage between the button tips until satisfied. It is entirely possible. But not for the hasty or impatient.
Torque is sometimes too much I.M.O. for the aluminum
Where's the shop where you work? Because I want to take my car across the street.I’ve dealt with too many seized plugs and broke many off. I do plugs by feel
Lol. Definitely don’t want to do that the place across the street is a Chinese restaurantWhere's the shop where you work? Because I want to take my car across the street.![]()
Across the street from one of only really competent mechanic's shop is a pie restaurant.Lol. Definitely don’t want to do that the place across the street is a Chinese restaurant. It’s not me that has torqued the ones down that have broken off it’s ones that have been done by other people and I broke them off trying to take them off.
