- Joined
- Nov 23, 2020
- Messages
- 542
Does anyone know for sure what the "additives " are? Or is this some "top secret blend" like Coke, or Colonel Sanders Recipe, that they carry around in a briefcase, handcuffed to someone's wrist?
Top Tier doesn't make anything. All they do is list minimum quantities of detergents in excess of EPA requirements. You can find pdfs from Top Tier if you search.Does anyone know for sure what the "additives " are? Or is this some "top secret blend" like Coke, or Colonel Sanders Recipe, that they carry around in a briefcase, handcuffed to someone's wrist?
Shell still uses their proprietary detergents. Chevron/Texaco still uses their proprietary detergents. Costco still uses whatever is lowest cost at the local fuel depot. At most Top Tier audits the station's purchase records to ensure sufficient detergents were purchased for the quantities of gasoline sold.
I don't know where you're at, but Shell and Chevron are the two most overpriced gas stations in my area, and in most all of the state I've been in. Some by over 50 cents a gallon...... Now every time I fill up at QT, I'm left wondering if I'm getting any worthy additive levels or should I have gone to Shell which has never removed their stickers.
I assume this website is up todate with its list of which brands in Canada are Toptier??
If so, I am very surprised how ESSO, Petro Canada, Huskey are not on the list!
WOW!!!
This is the site.. https://toptiergas.com/
Who knows what's up. They were all previously on the Top Tier list. Or at least Petro-Canada and Esso as of Nov 1, 2018.
WOW!!!
Citgo as a whole is Top Tier though they acknowledge having supply issues in SC. AR, and TX...Citgo is the cheapest by me. I'm not sure if it's top tier or not though.
TRICLEAN® GASOLINE
TriCLEAN gasoline is an enhanced, custom-blended fuel designed to help keep fuel injectors, intake valves and cylinders clean with continued use.
We know quality fuels are important to you, and you have our assurance that all three grades of our CITGO TriCLEAN® gasoline are TOP TIER™, surpassing the existing standards set by the EPA.
Hy-vee is decent. Casey is meh, kum n go is bad.Probably Hy-Vee or Casey's
Top Fear!!Will the crude from Iran and Venezuela make Top Tier?
