Too soon for a UOA?
Northern California, USA
Whats too soon for a used oil analysis?
I have about 1000 miles, and 6+ months, on my 5.3L V8 GMC motor and want to check for coolant and fuel dilution. I do short runs, less then 20 minutes, where the engine can get up to operating temps (200F) but I dont think the oil gets up to operating temps.
Is 1000 miles too soon?
I will only be doing a sample, I will NOT change the oil (unless the tests come back saying I need to change the oil)
I can't edit my post
The oil has 1000 miles, not the motor. The motor has 55k
If you don't smell fuel in your oil or it doesn't look or feel unusual, there is no reason to do a used oil analysis except to make yourself feel better or for educational purposes. Both are perfectly valid reasons.
OAI recommends sampling at 2000-7500 miles. If you think you have a leak or a fuel problem I would sample now. If anything it may let you sleep better.
