gathermewool
Site Donor 2023
This seems like the perfect instance for sending off a sample for analysis. Disregard the posts where people say you're good if you didn't get the low oil pressure light. That's a LOST PRESSURE light, meaning you're essentially hosed unless you shutdown right away. However, if you haven't done any hard cornering or flat-out acceleration recently, you're probably fine, so long as the loss in volume is due to consumption. If it was low to begin with, as some have suggested is possible, I'd be happy and sad. Happy, because that would mean you didn't consume much, even with low starting level; sad, because I ran for so long without knowing the true level - frustrating.
Originally Posted By: Linctex
Originally Posted By: Sn0wman
Hard to believe engine could have used up 3 quarts of oil.
What's even HARDER to believe is that you've *never* pulled the dipstick the entire time you have owned this car?!?!!?!?!
What's even HARDER to believe is that you read this post, but not the two posts that show the OP did check...
