IIRC, that head gasket business was remedied long ago. Not an issue anymore...There are some here who would suggest it will need three head gaskets by 100K.
So which is it?
So which is it?
I agree, but there's just no pleasing some people. "A friend of my uncle's barber had a Subaru and it blew its head gasket and the engine locked up solid as a rock..."IIRC, that head gasket business was remedied long ago. Not an issue anymore...
Or, maybe they wouldn't because they know it could extend the life of your engine past warranty! (kidding of course.....maybe.)
Ditto for me with a 24 Hybrid CRV . Minor damage but I traded it in . Never like a vehicle that has had body damage repaired .I had a 23 Subaru Forester. And I changed the oil at 100 miles and it was dirty full of metal shine, Grit, pieces of unknown at the bottom of the waste pan. Yes I do believe the filter should have picked up all that as well but they don't. Changed it again at 500 miles, still saw a lot of glitter and crap. Then did another change at 1500 miles. Very minimal glitter and crap at that point. Then at 2500 got rear-ended!
Oh the joys of car ownership!![]()
Filter can only catch what the pump picks up.Why aren't the oil filters trapping this " glitter " ?
Over the past 20+ years I have been on the BMW forums, I see a lot of issues with the o-rings provided with American made filters for BMW...Fram and STP come to mind in particular. The o-rings causing leaks or being over sized so the filter housing simply won't fit. I've never risked using them.I'm on a couple of BMW forums. There are some horror stories of how an aftermarket oil filter collapsed in the oil filter housing. I use only MANN filters.
At one point in my career I had access to a small fleet of "company cars". We got a nice new one for our fleet and I had the oil changed at about 1000 km. The finance people gave me a really hard time about that - like that was wasting the government's money. I said (speaking as a mechanical engineer) it was good practice but it was pretty clear they didn't believe me.I’ve had the same experience several times. First change between 500-1500 miles for me on new cars.
My grandfather went to the same barber. So he knows the story also. After the engine was replaced the CVT blew in less than 200 miles. Along with the radio. It was then listed of Craigslist "Subaru for sale, doesn't run but probably a simple fix".I agree, but there's just no pleasing some people. "A friend of my uncle's barber had a Subaru and it blew its head gasket and the engine locked up solid as a rock..."
Not just modern engines. All engines AFAIK. I like to put a pair of Filtermag magnets on oil filter, especially if it's a new car or rebuilt engine.So usually I just let my cars go long distances on the first factory oil fill, and change at the recommended mileage. On my new 2024 Subaru I just dumped the factory oil at 600 miles. I flushed the oil pan with a bit of fresh oil as well since I had some extra older oil sitting around not being used.
I switched the oil from the drain container I used as I will be dumping the used oil at a recycling location. It is a nice sunny day today and I could see all of the glitter in the oil as I transferred it between a couple of containers. I was surprised by the amount of actual metal sitting at the bottom of the containers, there was glitter being suspended in the oil which I expected, but quite a bit of metal that settled to the bottom of the container. I suspect it was mostly sitting in the bottom of the oil pan, as the oil filter did not pick it up. I went back and ran my finger through the glittery stuff, you could certainly feel it and rub it between your fingers, gritty feeling for sure.
I found about 3 pieces of metal that were a bit larger than grains of salt/sand , the rest of the material was much smaller, but very glittery. I am kind of glad that I got that metal out of the engine, it may not have harmed anything leaving it in there, but it was good to see how much metal comes out of these modern engines.
Obviously not the answer of people with their head stuck in the sand for at least the past 16-18 years, hanging on to the only true black eye that was a Subaru-only issue. All the other complaints are ones ubiquitous across pretty much all manufacturers.There are some here who would suggest it will need three head gaskets by 100K.
So which is it?
