- Joined
- Feb 15, 2025
- Messages
- 268
So usually I just let my cars go long distances on the first factory oil fill, and change at the recommended mileage. On my new 2024 Subaru I just dumped the factory oil at 600 miles. I flushed the oil pan with a bit of fresh oil as well since I had some extra older oil sitting around not being used.
I switched the oil from the drain container I used as I will be dumping the used oil at a recycling location. It is a nice sunny day today and I could see all of the glitter in the oil as I transferred it between a couple of containers. I was surprised by the amount of actual metal sitting at the bottom of the containers, there was glitter being suspended in the oil which I expected, but quite a bit of metal that settled to the bottom of the container. I suspect it was mostly sitting in the bottom of the oil pan, as the oil filter did not pick it up. I went back and ran my finger through the glittery stuff, you could certainly feel it and rub it between your fingers, gritty feeling for sure.
I found about 3 pieces of metal that were a bit larger than grains of salt/sand , the rest of the material was much smaller, but very glittery. I am kind of glad that I got that metal out of the engine, it may not have harmed anything leaving it in there, but it was good to see how much metal comes out of these modern engines.
