- Joined
- Jul 10, 2022
- Messages
- 5,984
Recently heard the phantom fill. Suspected the flapper but interestingly the parts are so cheap, I just replaced everything. The flapper did look like it was beginning to curl and I don't know when I last replaced it. Pretty sure I did a fill valve only last time, so likely 5-8 years ago.
Back in Feb we went overseas, so I turned off the entire house at the main shut off. When I opened it, heard some pop at the toilet. It seemed the not so old fill valve would make a surging noise when filling, which was another reason I went with replacing everything.
It's not the most fun idea separating bowl from tank, but I did it, and parts were only $21. Out of this the sponge? from tank to bowl is new, and at least the rubber washers which are inside the bowl are new. They turned the water black when touched as they were deteriorating. I put rubber washers on the outside as well.
I agree with the above, this is such a simple device (toilet) yet mysterious as well!
This is what I got and I didn't use the thing that goes to the fill tube, I used the old one
https://a.co/d/c8KvvWr
