Originally Posted By: oldhp
The threads are different; The correct threads are 22X1.5-6-H MM. The -6-H means the threads have a different pitch. Example would be metric nut on a standard thread bolt, it will kinda tighten but not right. You must use the 22 X 1.5-6-H threaded oil filters.
The FL-820-S crosses to a WIX 1372 which is 22 X 1.5 threads, won't work. The correct WIX filter is 57899 which is the correct 22 X 1.5-6-H threads.
The thread pitch is 1.5mm (thread peak-to-peak distance) ... that's in the size call-out of "22 x 1.5", which means 22mm dia by 1.5mm pitch. I thought the "6H" designator, or other call outs in that field, was the "thread engagement tightness". In other words, it means how much slop is in the fastener when assembled.
