Originally Posted By: Garak
Originally Posted By: goodtimes
I think that makes sense.
There are also metal particles from the rough edges. Will they stay, or will they leave subjected to oil flow? Some are really rough and ragged. Wide variations on almost every filter I have looked at. See bottom louvers in pictures. Squinting louvers. I can't use that.
Yes. The first one Z posted below your post is from the 51358 I returned. Of course, if you look at a Baldwin or Hastings, you tend to see well made louvers. Then, you don't have to worry about them being a defect.
The one I posted is a PF1233 I cut open. At the bottom of the first picture it shows almost closed louvers, like slits. The other side of the filter the louvers are much better opened. Champ and Puro use "two scoops", two separate opposing little hooded louvers. Baldwin/Hastings uses a different machine which cuts one scoop, opened on each end of the scoop. They are better but not immune from what I don't like, the possibility of steel particle shedding from the ragged, bad cuts. Like I said many, most, louvers are not sharp cut at the edges, they are pulled open. IMO, COD had good intuition about the louvers, may he RIP.
