Hi All,
After grenading my 200R4 (broke a sprag gear, quite spectacular to be honest), I bought a TKX 500.
It's a bit notchy still after a whopping 60 miles of break-in.
On the internet I read some people having luck with pennzoil Syncromesh and a better shift quality.
On the other hand, Tremec (whilst advertising that pennzoil and GM syncromesh is OK to use in their transmissions, say by mail that I shouldn't use a syncromesh fluid).
Confusion identifies.
Mobil 1 synthetic DIII atf seems one of the safe choices to make.
However, I'm European and when I look for Mobil 1 atf synthetic I get a variety of choices ( LV, SHC, ATF 220).
Amsoil ATF isn't allowed as it's not tested they (tremec) said by mail.
So 2 questions:
- What Fluid can I use sucessfully without messing up the syncros?
- And what's the partnumber of said fluid so I can search a little bit more accurately?
Bonus question: If you're European, what fluid are you using with succes?
As always, I thank you very very much.
So 2 questions:
