My show truck has a Tremec TKX 5 speed transmission
The problem is there is so much misinformation out there about what fluid to use. I dont think Tremec even knows
I was experiencing a minor TKX issue (non fluid related). I was running Amsoil signature ATF fluid after break in w no issues. I drained the fluid to check for metal.
I refilled w Pennzoil Synchromesh bc that's what the store had and I saw it was an approved fluid from a google search. However, I was later told by a transmission shop Tremec no longer recommendeds SM in the TKX.
Heres the twist. I called Tremec and spoke w a transmission tech. He said, no Sm, only a high quality ATF such as their brand or Mobil 1.
Now for the kicker. The same company emailed my buddy bc he had the same question. They sent him a list of Approved fluids
" We recommend TREMEC HP-MTF, GM Synchromeshâ„¢ or Mobil 1 Synthetic ATF". Wth....
Should i listen to the Guy I talked to or the email? I did buy a case of their brand fluid just to be safe. But until it comes I don't wana destroy my 3k transmission.
Also, if I drained the SM and added ATF will the residual SM clash with the ATF?
