My car is a 2010 Toyota Yaris with 140k miles.
All four of my tires are balding on their outside edges. I rotate my tires at the Toyota recommended interval which is every 5k miles and keep the tires correctly inflated at 32 psi. I check my tires' inflation twice a month and add pressure if necessary.
I got a wheel alignment from a non-chain shop with a lot of good Yelp reviews 28k miles ago because my tires started wearing on their outside edges. But my tires have continued wearing on their outside edges.
My car shows none of the symptoms of misaligned wheels except uneven tire wearulling to one side, uneven, loose or vibrating steering wheel, squealing tires, etc. When looking at the tires from the front of the car it is very difficult to see any misalignment in either front tire. I have tried doing my own alignments with the string stretched along each of the car method to measure toe and using a digital angle measuring tool to measure camber. But right after I made toe adjustments with the tie rods I took my car in for an alignment and the technician said my toe measurements were way out of spec.
If I take my car to a shop for an alignment check they are most likely going to go ahead and do an alignment even if the measurements are just a little out of spec. Alignments are expensive. I had a lifetime alignment deal with Firestone Tire, but the chain stores have horrendous reputations. Even though I had regular alignments done at Firestone on my previous car the tires still wore very unevenly, so I believe they were either not doing the alignments or did not know what they were doing.
So is there a way to tell if a car's wheels are out of alignment if there are no symptoms besides tire wear? Ideally I would like to know if the wheels are misaligned before they start screwing up the tires. Is the only option to trust a shop with a lot of good reviews to only do an alignment if it's necessary? Thanks for any replies.
