Tire/wheel required no weight to balance?
I have driven a million miles in outside sales. Bought many cars and many tires. I have had multiple brands of tires not require any weight to balance. Never more than 1 per set.
I don't buy the most expensive tire, usually Yokohama tires that are mid priced.
Great all around tire that gets the job done.
It happens every now and then - with all brands, even Cooper which is disparaged in a post above. I've got TWO Cooper tires on my F150 right now that required no weight to balance them.
Oem tires and wheels, both of which are built to tighter tolerances, and tested and marked for runout and road force variance, and match mounted stiff spot on tire to low spot on wheel.....still take some weight to balance... and sometimes a fair bit...
Getting a zero weight balanced wheel/tire assembly is just luck... In my driving experience, with probably 50 tires or more, in many brands, I think I've had maybe 2 or 3 that took no weight, one recently being a Toyo winter tire.
And I took that one back because I wondered if they forgot to balance that one...!
I think oem wheels put on a thin clip or similar to show that the wheel has in fact been balanced.
