Hi guys, My 2004 Buick Lesabre has the original Michelin Symmetry tires on it w/48k miles. Tread on them is not bad but will be replacing them after winter. I have a set of two Cooper Weather-Master ST2's from another car that I would like to put on the Buick for the winter(and buy another set of two so that I have a complete set).
Standing up the Coopers & Michelins side by side, the Coopers are shorter. The Coopers measure approximately 26.25" and the Michelins 26.5". The Michelins have 47k miles while the Coopers only have a couple winter seasons on them. Both are 225 60 R16.
Is this difference in diameter to be expected when buying across different tires and manufacturers?
This seems like quite a big different given the tread wear of the smaller tire is less.
It's a little annoying because my Buick has the Gran Touring package with the shorter final drive ratio, so it already turns enough RPMs.
Thanks
Thanks
