Originally Posted By: NMBurb02
Here in the People's Republic of California (not sure if elsewhere as well) shops are required to check tire pressure whenever they service a car and adjust the pressure as necessary. The GP calls for 30 psi front and back, but the independent shop I use fills to 40 psi every time. It makes for a harsh ride but is below the max psi on the tires (50 IIRC) so I'll typically drive around with it at 40 for a while and then bleed to 33-35 when I get around to it.
The Burb's tires are slightly oversized (1 inch/3% taller, same width) and I've never been able to figure out how I need to adjust the placard pressure of 35 psi to account for the difference in volume, despite reading advice on multiple sources (some say higher pressure, some say lower). I tried the chalk method but messed it up somehow and plan on trying it again.
I believe Costco fills with Nitrogen and the one time I purchased tires there is probably the only time I have used nitrogen.
I would still run the recommended pressure for normal driving with slightly taller tires. I wouldn't try to adjust unless it shows uneven wear, or you are racing, towing, or off-roading.
