Tire Pressure Gauge
Originally Posted by BusyLittleShop
Angle valve stems are the best solution for easy access in tight conditions...
Yeah, if you're not running tubes and have access issues they can be great.
I've had "right angle" valve stems in both 90 degree and 83 degree variants, and 83 is a safer bet than 90. In the case I remember with the 90, the inflation end had minimal clearance with the rim and I had to use an adapter to inflate the tire.
