Originally Posted By: old1
It is a 65 mustang coupe 6 cyl automatic, with 195-75-14 tires, which are suppose to be the modern equivilant of the original size which I don't remember of the top of my head, and the original owners manual calls for 28 to 30 psi, and I simply wondered if with the modern tires if I needed less, or the same or more psi. I am just gonna try 30 and see how it works. No sweat!
Thank you, thank you, thank you.
According to Tire Guides, a 1965 Ford Mustang originally came with 6.94-14's inflated to 24 psi front and rear.
That means Ford specified a load carrying of 1050# for each tire.
I wrote up an equivalency chart and published it here:
Barry's Tire Tech - Vintage Tire Exchange
And I think a 185/75R14 is the closest modern equivalent. But if you are using a 195/75R14, then you should be aware that the stock rim was 5" wide and a 195/75R14 calls for a minimum of 5 1/2". That is going to cause the tire to arch across the tread face and wear in the center. It will also cause the vehicle to be sensitive to crosswinds and pavement irregularities, such as grooves and ruts.
Also, the 195's are 1/2 wider, even compensating for the rim width difference - and while I doubt there is a clearance issue (those vehicle had a ton of clearance), it might be good to check - keeping in mind that the worst condition is the suspension fully compressed and the steering wheel fully turned.
But if I do the math, the equivalent inflation pressure would be ...... drumroll ...... 19 psi or 5 psi less! I don't like that answer.
First, it was pretty common back in those days for car manufacturers to specify marginal tire sizes. Nowadays car manufacturers do a better job. So if we add what we've learned about tire sizing over the years, I get 32 psi.
OK, so that is not much different than your takeaway, but at least we have a technical basis behind the answer.
