CrossClimate2 105 load rating (XL) vs 102
Owen Lucas
$100 Site Donor 2023
Time for new tires on our 21 Honda Pilot 245/50R20. Costco is temporarily out of stock of the 102 load rating and only has the XL version in stock.
Would there be a noticeable difference in ride with an XL tire vs a regular 102 load rating? I don't mind waiting another week or 2 or going to Discount Tire if necessary.
"The XL tire (#1823626) is reinforced to handle a higher load capacity - about 165 lbs more per tire. This means it has a stronger sidewall construction designed for heavier vehicles or applications requiring higher load capacity."
  1. Tire #1465941: 245/50R20
    • Load Index: 102 (1,874 lbs per tire)
    • Regular sidewall construction (no XL designation)
  2. Tire #1823626: 245/50R20/XL
    • Load Index: 105 (2,039 lbs per tire)
    • XL (Extra Load) designation, indicated by "/XL" in the size
I would go XL everytime. Built to withstand more is always better. Loss of ride comfort will be slight on your Honda, as it is sprung fairly soft.
The 102v has been discontinued. Michelin consolidated the line to fit a broader application and reduce MSPN's. You would never know the difference driving on them.
