Bias vs Radial Trailer Tires
Houston, TX
I have a light tower that will live in my yard, and odds are it never moves. But its possible it would get towed somewhere once or twice. It has really old, super dry rotted tires
Can anyone weigh in on Radial vs Bias ply tires? I heard that Bias ply holds up better over time, even though you usually get less milage out of them. Since I won't be going many miles at all, it doesn't really matter
I'm looking at $235 all in from Discount Tire for Bias Ply, Radial has more choices and is slightly cheaper
I’ve had good luck getting trailer tires from Walmart often already mounted ready to bolt on. Might check into that type of option. I don’t think there is a huge difference as long as they meet the required load ratings.
That's a lot of money! When my tow dolly tires started cracking after 25 years in the sunshine I got new ones from Walmart for $26 each and mounted them myself.
I'm running Carlisle 6ply bias tires on my trailer no problems. Get 'em at your local DT and have DT mount and balance the tires for you. You can even just drive your trailer to DT and let them do it all for you. Hope this helps.
i've learned, anything new, that's better then what's on the trailer, will always be less dangerous when what's currently on the trailer.
Especially tires. They don't last. They never last. They cannot last. They're built to not last.
This comes from a man who had over 4100 tires in the backyard all across the 30 acres. I guess my old man wanted the iron of the rims. Well, i had a surprise in life, and they needed to gone in 3 months. The local recycler was selling the business out of state, and after that there was no one in the area to help me out. Then, after the 4 53ft semi trailers were delivered, i read the fine print, on the 3 month trailer contract, and apparently i didn't see the "no rims" part...(!!!!!!!) I had an angry moment in life.
10.00-20's, and 22.5 daytons are a brute to handle. had over 1000 of those.
I won. And i didn't use a tire changer.
TL;DR, just buy anything new, and don't roll down the road if it's more then 8-10 years old. They're unsafe and questionable. And don't collect them!
You can get tires with rims cheaper than that… last trailer spare I bought was $70 for a 205/75/15 with rim. Check fb market place lots of places near me have trailer wheels/tires by the pallet in different sizes. Here is a guy that has 13's with wheels for $72 for example
https://www.facebook.com/share/15rthjuWU2/
I have heard that bias tires last longer. I got 10yrs out of the last 12in set on my boat trailer
Radials roll better for less drag.
Radials roll better, flex less, are more puncture resistant etc. You wouldn't go back to using a points type ignition or , kerosene headlights. Not sure why bias ply is even a thing anymore.
I thought trailer tires were essentially bias ply tires which can carry more weight. Was told never put radials on a load carrying trailer like camper or boat. Some folks can fit a LT tire on a trailer and be ok. ??
Oh boy, do I need to comment!!
There's a type of tire called an ST tire. They are designed specifically for trailers. They come in sizes that look like passenger car tires, so they put the letters "ST" in front of the numbers so they won't get confused, because ST tires can carry a lot more load than a P type tire. As a general rule, you shouldn't put a P type tire on a trailer.
As far as a radial tire having more sidewall flex, that's sort of true, but radial trailer tires are designed with stiffer sidewalls and are no more prone to fish tailing than bias ply trailer tires.
