- Joined
- Jul 17, 2025
- Messages
- 35
Does anyone have any experience with, or opinions on, the "clamp to the battery terminals" type tire inflators vs the "plug into the cigarette lighter" types?
They are basically the same (at the compressor side). 12V DC.Does anyone have any experience with, or opinions on, the "clamp to the battery terminals" type tire inflators vs the "plug into the cigarette lighter" types?
That is not fully correct. You can spend $150 on 12V compressor which can draw significantly more amps and are used typically by folks off-roading. They are substantially larger and more efficient.They are basically the same (at the compressor side). 12V DC.
The cigarette style will just be a little more sensitive for popping a fuse from too much draw, but many come with both adapters. Alternatively you can turn any cigarette style into a direct to battery with adapter or splicing on alligator clips.
Sorry, I wasn't clear enough in my explanation. I don't mean to suggest you can successfully run something that exceeds the amperage of the cigarette plug.That is not fully correct. You can spend $150 on 12V compressor which can draw significantly more amps and are used typically by folks off-roading. They are substantially larger and more efficient.
I have the Milwaukee 12v too. It's really nice, just dreadfully slow for car tiresI've got the 12v Milwaukee. Its great. The only downside is that I never have it in hand when I need it.
Thanks-just ordered a Noco inflator and an alligator clamps adapator. Expect they will work together.They are basically the same (at the compressor side). 12V DC.
Did just that-ordered a Noco inflator and a battery clamps adaptor. Should work well. Thanks for the advice.i have a plug in one in my car for emergency use. i think in the last 10 years they have gotten a lot more efficient with amp draw. i have one a long time ago , and when i plugged it in , it would pop the fuse as soon as it started up.
you can always have the best of both worlds , and get a battery clamp adapter for the cig lighter model
