In June, I had my new Cooper CS4's installed at Walmart. In July, I put in new front L&R Lower Control Arms(Dorman) as the others were very sloppy along with a 4 wheel alignment. Now, I notice the tires are out of balance.
I did bring the car back to W*M to have them rebalance the tires again at the beginning of this month/August...same thing, still out of balance!
Maybe it's the control arms?
___________________________________________________________________
BTW, I also brought in one tire from my wifes car(leaking) for a flat repair in which they remove the tire from the wheel to fix it. Now, this tire too is out of balance and it was fine prior to taking it to W*M. Yes, they actually did rebalance this tires as the led weight is new and in a different spot on the wheel.
I've been having W*M install my tires for quite some time and have had excellent success. I may need to call the store mgr and have them check their machine as I think that they should have the tire balance machine calibrated on a regular basis.
