didnt some engines in the 30s-40s have only gears? iam not THAT old.
Donald said:Yes, many GM engines for years had timing sets with nylon coated cam gears which were notorious for the teeth breaking off with age and mileage.
If things got bad enough the broken teeth would clog the oil pickup and seize the engine. Don't ask me how I know.
The 2.5 Iron duke in my S-10 has timing gears, metal on crank, nylon on cam. It's not a matter of if they fail, it's when. Had to replace mine, and they're not set up for any sort of easy remove and re-install. Apparently GM thought they'd last forever..![]()
Well, they typically fail north of 100,000 miles, which years ago, was about the life span of the average vehicle as the engines would start burning oil or rust out by then.
Also, cars were less expensive back then, people had more disposable income and didn't have to drive their old cars forever, just trade-in on a new model or low mile used.
