All:
Check out the link for a series of pictures of the damage done when the rear camshaft sprocket slipped 2 notches. The damage is amazing.
Question: does anyone think this engine is worth saving?
The engine is in a 1999 Chrysler Cirrus. It's a 2.5L V6 with 134,000 miles. It was in great shape before the "incident". My last 3,200 OCI finished with no noticeable oil consumption. The engine was strong, smooth, and so was the transmission. I bought the car at 129,000 miles and replaced all the hoses, new PS pump, new plugs, new plug wires, PCV, drive belts, and the timing belt and pulleys. Shoot, I can still see the original hone markings on the cylinder walls. The heads to totally clean with no sludge or discoloration whatsoever.
I suspect the sprocket slipped the notches because it stretched after the break-in. I probably didn't set the tension tight enough--at least that's what I think. And, oh yes, it was a Gates belt...
I was thinking of dropping the oil pan, cleaning out all the metal flakes, replacing the pistons, rings, connecting rods, rod bearing, cylinder head (complete - valves and camshaft) , and just honing the bores ever so lightly. I'd do this all in the car--without pulling the engine.
My guess is parts and tools would be around $1,200-$1,500.
Is it worth it? Just replace with a cheapie rebuilt? Or just junk her???
http://mysite.verizon.net/resqbxff/mychryslercirrustimingbeltfailure/
