I have a 2004 Mercury Marauder with 25,000 miles, I was wondering if it is time for 6 ounces of Auto-Rx.
I am going to be changing the fluid in the pan as well as the trans filter at 30,000 miles. I was thinking of adding 6 ounces of Auto-Rx at 29,000 miles.
I believe there is a magnet in the pan and I did put a Filtermag magnet on the bottom of the pan. I am just wondering if it is too soon for Auto-Rx in the trans or maybe I should wait until something like 60,000 miles.
The transmission is running fine and the car came with a big factory external transmission cooler on it, the only thing I do not like about it is that the trans cooler has a 180 degree thermostat that obviously does not let fluid go through the cooler until it reaches 180 degrees.
As far as trans fluid, I can either use Amsoil ATF or just stick with what is in there, I believe it has Motorcraft Mercon V from the factory.
