I just acquired a BMW 740iL with the 4.4L V-8. The car was not running and had been sitting for what I would guess is at least a year. The previous owner had left a few cans of random oil treatments and sea foam in the car and another individual had added a qt of Dexron III to the oil. Now that I have the engine running I am loosing oil pressure after a short distance of drive time. I had both valve covers off and there was a fair bit of oil "sludge" in the cylinder heads. I have also removed the oil pan at least 5-6 times to clean out the oil pump pickup. What I assume is going on is the additives and or atf are causing the debris and gunk to loosen and migrate to the oil pan where they are picked up by the oil pump and then clog the pickup.
So to remedy this I have been removing the pan, cleaning the pickup and straining the oil through a very fine mesh filter and replacing the oil filter when it looks significantly soiled. But this is time consuming and a slow process, I feel the more I do this the closer I am to causing significant engine damage, i.e. wiping the bearings. With that said though it IS working, as I have been able to run the engine progressively longer before the pickup clogs, but every time I drop the pan at this point I have just a slight amount of sludge (only enough to cause the pickup to clog).
I am looking into other options now. I have never been much of a fan in regards to "Oil Flush" treatments, but I think in this case it may not be a bad idea as I can easily remove the oil pan. What is the collective idea on this for my situation?
Thanks in advance, George
